Component Board vs Component/SVHS/Composite Dual Slot Terminal Board
Discussion in 'Plasma TVs' started by Novi, Jan 10, 2005.
  1. Novi
    Novi
    Just wanted to check whether the BNC 'Component/SVHS/Composite
    Dual Slot Terminal Board', being offered by AV Sales, would
    a) Offer the same quality component PQ as a dedicated component board
    b) Whether, using this board and having connections into both Component and Composite would allow me to use the PiP option.
  2. Krance
    Krance
    I have the board you speak off, effectivly this is exactly the same board as the component board.... then you get s-video (handy for DV cameras) and the other terrible one to the other slot.
    I'm not sure you would even want to use the composite connection... I tried the S-video and that's bad enough (not bad but never as good as progressive).. and I couldn't tell you if that means you can use PiP (I thought you need the tuner for that?)
  3. vileda
    vileda
    Oct 15, 2004
    401
    Sunderland, Tyne & Wear
    This may answer your second question.
    here
  4. Novi
    Novi
    duh :oops: should have checked the threads before posting !
    Thank you vileda for pointing me to the applicable thread
  5. vileda
    vileda
    Oct 15, 2004
    401
    no problem, I'll be interested to see if there is a quality difference as I'm taking delivery of mine this FRIDAY :clap:
  6. Krance
    Krance
    I have had both cards... both are the same... :)
    by the way, I tried the PiP with s-video and component and it works fine, although I can't see myself using it... had a little fun with it though
  7. Repo
    Repo
    Jul 21, 2004
    430
    Sheffield, UK.
    +21
    I've got the dual slot board. PiP works fine but it's not really that useful for me & the extra money I paid for the dual board over the single slot component board hasn't really been worth it.
    HTH :)
  8. midiman
    midiman
    Jan 8, 2005
    320
    London
    But you still get the benefit of being able to connect 2 devices in at the same time. Admitedly the S-Video/Composite iisnt as good as the component connection
  9. Repo
    Repo
    Jul 21, 2004
    430
    Sheffield, UK.
    +21
    That was the general idea but as I've routed everything through the 3805 it's not turned out to be a great idea :D
