component as composite?
Discussion in 'Cables & Switches' started by scotben, Jan 5, 2007.
  1. scotben
    scotben
    can i use one of my component cables to carry a composite signal?
    the reason for this is that my mate is bringing round his xbox 360. I use component to hook my dvd up to my projector which is 10 metres away at the other side of the room. the xbox output he has is composite which i know is poor quality but was wondering if i could use a composite female to female coupler to connect the xbox video output to my component cable and into my projector?
    thanks
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,472
    2
    +1,365
    Once you connect it to a composite input on your projector end.
  3. scotben
    scotben
    yes my projector does have a composite input.
    thanks
