Component Amp Question
Discussion in 'AV Receivers & Amplifiers' started by woody123, Oct 16, 2003.
  1. woody123
    woody123
    Jun 30, 2003
    65
    Chelmsford
    Please does anyone know of an Amp that has more then two Component inputs. I like the price of the Denon 3803 and don't really want to spend much more. Is the 3803 due to be upgraded anytime soon, should I wait?
    Also can I run an RGB signal over an S-video onnector - is this possible? - would I loose any quality? (using a Scart to S-video connector).
    Thank you.
    James
  2. magking
    magking
    Jan 6, 2001
    378
    Norway
    Denon AVC A11SR has three component inputs.
    You could try to find one second hand.
    You can not run RGB over an S-video cable.
  3. timlloyd
    timlloyd
    Jan 15, 2003
    278
    Warwick
    +9
    Dont know about amps with more than 2 component inputs but there are amps that do video up-conversion which may be of help, i.e. feed it s-video (Sky+ perhaps?) and it will then output component.
    3 I think that do it are
    Sony DB2000 ~ £380
    Marantz 7400 ~ £480
    Denon 3803 ~ £680
  4. woody123
    woody123
    Jun 30, 2003
    65
    Chelmsford
    Cheers for you help guys.
