component advice
atodd66
hi can anyone tell me if component video rgb cary sound as well as picture?
if not what should i use for sound ?
its for an old tosh SD-220e to panny 46g15.
dablk
On the dvd player are you talking about setting your scart lead to rgb in the menus? if so then yes a fully wired scart would carry the audio aswell.
If its the 3 component RCAs on the back of the unit then no its just picture. You would then need to run the two L/R audio RCA connectors aswell. So 5 Cables.
dablk
atodd66
thanks for that
from what i can gather if i use the Y Pb Pr (GBR) it will give the best picture to the tv, it then gets upscaled by the tv
then i would use the R/L ANALOG (red/white phono cables) for the sound ?
have i got that right ?
w3dal
thanks for that
that would work :)
just make sure you set the DVD player to output component in the menu
Enjoy
Dal
MarkE19
Yep! :thumbsup:
Just be careful not to get RGB (available in several different versions - RGsB, RGBcvS & RGBHV) confused with YUV Component (Y Pb Pr & Y Cb Cr) as they are not the same even although they are connected with Red, Green & Blue phono's :rolleyes:
Mark.
