Component advice for second system
Discussion in 'Cables & Switches' started by daveb975, Nov 21, 2004.
  1. daveb975
    daveb975
    Oct 25, 2002
    4,248
    103
    London
    +347
    I have just set up a second AV system, which consists of a Denon DHT500SD system running into a Toshiba 26WL46 LCD TV.
    I am currently using a cheap £10 component cable to connect the two.
    When I upgraded from a similar cable to a Belden 7710A based cable on my main system (Denon DVD2200 into a Panasonic plasma) I was very pleased with the improvement.
    Unfortunately, I am unable to try this cable on my second system as it is BNC terminated for the plasma.
    The question is, will I notice a real difference if I upgrade to a Vandamme/Belden type cable on my second system given the size of the screen (26"), and the quality of the DVD player?
