Componant
Discussion in 'Xbox Forums' started by dann, Aug 29, 2006.
  1. dann
    dann
    Aug 25, 2003
    134
    Hi Guys.
    I am going to get a componant switcher as I have more than one source.
    Before I do can anyone tell me if I can still view the 360 though componant on a NON. HD plasma.
    I cannot check cause the tv is on the wall & cables are buried.
    Dan
  2. beasty54
    beasty54
    Mar 16, 2005
    6,188
    Lincoln
    +525
    You sure can, 480p should look nice
  3. andrewrunagall
    andrewrunagall
    Sep 4, 2005
    1,162
    Hadleigh, Essex
    +63
    Yes, you can. You'll have to set the switch to Standard Definition on the lead, but other than that, you'll be getting quality pictures, just not in HD.
  4. dann
    dann
    Aug 25, 2003
    134
    Thanks guys.
    Just for anyones info, I am looking at getting an Audio Authority 1154A.
    If anyone is interested I will let you know how I get on.
    Dan
  5. geese
    geese
    Sep 13, 2004
    772
    28
    Denmark
    +46
    :thumbsup: ..The AA1154A is great. I have it connected to a yamaha dvd player...xb360....and an xbox. No signal lost at all.....and very easy to set-up.
  6. hs77
    hs77
    Dec 15, 2004
    56
    +5
    Your plasma will take a 1080i signal over component, so it should look great!
  7. dann
    dann
    Aug 25, 2003
    134
    Hi Guys,
    Just to update, I have gone for a Zektor HDS4.1, I chose this because I can source in UK & had some spare cash!
    Right my next question, Will running my sky (non HD) though the Zektor make any difference to the picture quality? I was thinking it would not as the source signal starts at scart & cannot be improved just by changing the type of cable.
    Can anyone confirm this?
    Dan
