Componant cable for the XBOX?
Gary D
does anyone know if you can buy a componant video cable for the xbox? I suspect that there isn't but i thought i'd ask
thanks folks
Gary
There is - I got mine from Game (£24.99 by Gamester) Connected it to my AE100 and it confirms that it receives an interlaced piccy!!
Only thing is is that you only get DD Opt out when using component - the phono left/right isn't enabled (it is when using sVid though)
Gary D
roger, sorry for being dense, but it is COMPONANT and not comporsite?
i've just bought a huge new telly with componant video inputs and would like to play halo through it.
i've looked at the game website and nothing is listed. after a wider search on the web i found a few cables listed , most notably the advanced hi def pack that you can buy in the US, but i can find nothing listed for britain (and i suspect that the US one wont work with a UK xbox.)
any info would be gratefully recieved.
thanks in advance
gary
fuzzybee
Gary
Yes the US High Deff pack does work with the uk xbox but you will only get a interlaced component picture not Prog Scan
I bought mine from Raven games and it cost me £40:eek:
I nolonger have a xbox so if you are interested I will sell it you at the right price;)
Pm me if you are interested:)
Gary D
fuzzybee, i've just bought the cable that rogeralpine mentioned, sorry. why did you get rid of the best console on the planet?
Gary
Yes - it is component, but I think you know that already ;)
I am suitably impressed with it - let me know what you think of it?
DVDcake
I brought this cable and connected it to a Panasonic LC75e projector via a VGA to BNC breakout cable as the component inputs are part of the HD15 socket. However I find that I get faint green vertical bands on the picture with DVDs although it does not affect games. I also have Microsoft's own component cable, brought from Canada but find that the green bands are even worse on this. Has anyone any idea what causes this?:confused:
Also I thought the UK X-box was supposed to be able to do a progressive picture at least with the games. It is only the US one that can do this and if so how can Gamester call their cable 'Hi-Def'? I would hardly call a bit less noise than S-video high definition. :rolleyes:
DVDcake
Just read another post in the LCD projector section that answers my own question. The UK Xbox needs to be chipped and then set to NTSC using a Video Select CD to allow the progressive options to be activated in the video menu. Seems the UK was never intended to get 'Hi-Def' out of the standard Xbox.:mad:
Podcast: CES '22 TV Announcement Round-up, Plus, Most Anticipated Movies of 2022 and More...
