Just recently my Logitech G51 speakers, have started making completely random popping noises. They are connected to an Auzentech X-Fi Forte with latest drivers (9th September 2011). All of these I have been using without issues since mid-2009.
The first time it happened I wasn't doing anything in particular, just reading a website (not listening to music or gaming etc).
It started very briefly with just two 2-second instances of popping in a single day.
Two days later it seems to have gotten worse. I'll usually get two to three 30 to 40 second instances of sequential popping each day, no matter what I'm doing on the PC. They can happen in intervals of minutes to several hours, up to 5 hours or so. This is becoming very annoying/scary when I'm just reading something, listening to music or playing games.
Seems like only the front speakers (which are closer to PC + electrical connections) will produce the noise.
At the time this was happening I noticed in my Sound Settings that both Microphone and Microphone FP reported as capturing very LOUD noise, even though there are none plugged in. The Microphone source, even with no mic present, always captures some static/buzzing noise and some PC audio somehow (not to mention it also captures the sound of me tapping the PC case - this I didn't know was possible - it's like there's a small microphone inside the sound card itself?).
Even though the noise is being captured by recording sources it doesn't mean the speakers will reproduce it as well. It seems to take some time before they do, or they don't at all.
I've recorded the loud noise they captured:
#1 http://soundcloud.com/asclepius123/random-popping-noise
#2 http://soundcloud.com/asclepius123/random-popping-again
#3 http://soundcloud.com/asclepius123/random-popping-yet-again
I've read something as simple as a worn fan bearing can cause static and popping in the line? If so my PSU's fan has been squeaking now and then lately (it has been for some time now), but I never noticed any connection to the popping noise.
I cleaned all the dust between the wires, re-seated sound card, re-plugged all audio connections. Left only my UPS (which has both PC and Monitor connected to it) on with everything else off: still had an instance of the noise being picked up by the "microphone".
Anyone know what could be the source of this? From the sound samples do you think it's possible to determine the nature of the source (EMI, house electrical interference, PSU fan, CPU/Mobo, sound card)?
I think it's safe to say it's not the speakers at fault (at least directly), but either inside the PC or electrical. Though the complete randomness of it still leaves me scratching my head on what is causing the noise and why it's making it.
