Completely Clueless
Discussion in 'Desktop & Laptop Computers Forum' started by Jimmer, Mar 8, 2006.
  1. Jimmer
    Jimmer
    Mar 7, 2006
    696
    46
    The Lakes
    +125
    Hi:hiya: firstly i'll start with an appology, as this has probably been posted a 1000 times before, but i've been trauling through the forum for a couple of hours now, and I just want some extra help/advice/confirmations!!!!
    Firstly, i'm looking to build a htpc. I currently have a sky box (not sky+) and want to run that through it, be able to change channels through it etc etc. Also I have a denon amp with all my speakers off that, I also want to be able to hook that up to it so everything runs through the pc.That's basically it I guess, sky through it and my stack system through it. So what I want to know is where to start with regards to the components needed to make this happen. I've built plenty of pc's before so I know what i'm doing when it comes to putting it together. I'm thinking a shuttle case, 1 gb ram, 250gb hdd, dvd, 3000+64 cpu and then i'm stuck. Advice most welcome!!!!
    cheers Jay
  2. Jimmer
    Jimmer
    Mar 7, 2006
    696
    46
    The Lakes
    +125
    This is what i'm looking at so far.....
    Asus T2-AE1 Athlon64 SKT754Audio LAN Mirage
    AMD Athlon 64 3000+ Skt754
    1Gb PC3200
    Maxtor 6L300S0 DiamondMax 10 300GB 7200RPM
    Samsung SH-W162C 16x DVD±RW
    good choices?just need to decide on the other bits i'm not too sure on!
  3. doink
    doink
    one thing i would say is to avoid the shuttle case... they are not the quietest of boxes.
  4. Jimmer
    Jimmer
    Mar 7, 2006
    696
    46
    The Lakes
    +125
    cheers. I'll steer clear!
  5. 99Flake
    99Flake
    What is your budget for a machine? Quiet PC do an HTPC for about £1100 that comes as a kit that you build yourself. Uses a Pentium M so there is plenty of power and no need for a fan, just a big heatsink. Looks perfect for HTPC use, especially as it has a front display to show MP3/Film titles as well as RSS feeds and system temps etc. Also has a remote. Let me know how much you want to spend and I can help you spec a machine.
  6. smidster
    smidster
    Jun 4, 2005
    43
    London
    I'd also have a look at this site - http://www.mediapc.tv/
    They have a good range with starter kits of all tried and tested components for a quiet set-up or will build to your spec.
    Just ordered mine from them - good customer service as well.
  7. Jimmer
    Jimmer
    Mar 7, 2006
    696
    46
    The Lakes
    +125
    I don't really have a budget in mind, although the cheaper the better! All the above spec that I wrote down comes to a shade over £322 so I thought I was doing well! Is that not such a good setup? What am I missing in respect to tv card (for sky) etc. Also, are the miniITX boards powerful enough for this kind of application?
  8. Jimmer
    Jimmer
    Mar 7, 2006
    696
    46
    The Lakes
    +125
    They look good mate cheers! Customer service is important to me since last ordering from da*s....
