Complete System
lazymatt
The problem with most of these, is the interface makes them a right pain to use.
If you've got a network set up, a streamer like the Squeezebox 3 is probably the best solution. Sounds great and easy to use.
Get yourself an SB3 and a NAS drive (Qnap TS101 is the easiest to work with). Plug the SB3 intop your existing hi-fi, and you can stream your music from the NAS without having the PC on.
Adam Shaw
The Hitachi also has no external phono input, so if you want to run the sound from your TV/games console, etc through it, you cant.
Quincy
Brought the Hitachi, but its going straight back, Sound quality is poor (constant Humming). and the mp3 navigation is terible
Podcast: Best Home Cinema Sources and B&W 805 D4 Speaker Review and more...
