complete system, help please??
Discussion in 'Blu-ray & DVD Players & Recorders' started by Irish1, Feb 18, 2003.
  1. Irish1
    Irish1
    Feb 13, 2003
    35
    Carlow Ireland
    Hi ok, I need some of your expertise, I'm buying a lcd projector(panasonic AE100), now I need a dvd home cinema system.
    What I want:
    I want a good system with plenty of power, I like to raise the volume. I want a high end system but it doesn't have to be the best out there my hearing isn't that senistive.
    I want a DVD player that will give my projector the best picture, So I take it I'l need one with progression scan.
    I want to connect my sky box and a ps2 to the system so I can get full use of the whole lot.
    So what system will let me do all this for under €2000.
    Its hard to get some of this equipment in ireland but I can get any sony product so if theres a sony product which will do all I want. I'd really apprectiate some one telling waht it is?
    Plus can anyone tell me what cables etc i will need.
    Thanks a million
    :confused:
  2. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Do NOT buy that Panasonic projector. Aside from not being that good the problems inherent in them are limitless. If you're looking for a budget LCD projector instead opt for a Sanyo PLVZ1 or PLV30. Even better spend a little more on the £2000 optoma HT50, which is of the superior DLP type.
    As for the rest of your system, I'd suggest opting for the Sony STRDB1080 A/V receiver, Kef KHT2005 (if you can find them - because they're absolutely fantastic), and a Toshiba SD900E (which I just bought from hyperfi for £399).
  3. Irish1
    Irish1
    Feb 13, 2003
    35
    Carlow Ireland
    I know the panasonic isn't the greatest but it is good, and also I'm finding it almost impossible to find suppliers of projectors in Ireland. The only real options I have here are as follows:
    Panasonic AE100 : €1600
    Sony VPL-HS1 : €2900
    Sony VPL-HS2 : €2300
    Epson EMP-TS10 : €2489
    Sharp PG-C20XE : €2760.00
    Sharp XV-Z90E : €2818.00
    So Which would you pick?
    Thanks for the help
