Complete newbie speaker question
Discussion in 'Home Cinema Speakers' started by FizzyFizz, Apr 23, 2007.
  1. FizzyFizz
    FizzyFizz
    Nov 24, 2005
    24
    I've just purchased my first 50" plasma and now want to start thinking about speakers. I don't have a CLUE when it comes to this sort of thing! I've heard a thing or two about AV receivers. Would I need one of these or would an amplifier on it's own be ok? (...assuming the speakers don't just plug into the back of the TV?)
    I suppose I'd have about £400 to spend at a push.
  2. leon
    leon
    May 15, 2001
    1,160
    kent
    +67
    you can buy av receiver with amps built in its a good place to start there are speaker packages out there .i would stick with the same make of speakers to get a better balance of sound a good make to look for is yamaha ..or denon these will have a bigger range to match your price ..
  3. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
  4. ric449
    ric449
    Dec 8, 2004
    20
    I am also interested in the Yamaha setup you mentioned, but I noticed something- the lack of HDMI. Are there any receivers in this price range that include HDMI? Even if you can recommend a set of speakers and a good receiver as separates, that would be a lot of help.
