Compatible HDMI Board?
Discussion in 'Plasma TVs Forum' started by whitestripes, Aug 6, 2005.
  1. whitestripes
    whitestripes
    Is the Panasonic TH42PWD6 plasma screen compatible with the TY-FB7HM HDMI board? If not, are there any other compatible HDMI or DVI boards for this make of plasma?
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,175
    Norwich
    +795
  3. whitestripes
    whitestripes
    Thanks!
    Sky HD recommends either an analogue component connection or a DVI (with HDCP) (or HDMI which is not compatible with this model).
    With which connection (component/DVI+HDCP) would I receive a better picture when a HD signal is broadcast??
  4. Thatsnotmynaim
    Thatsnotmynaim
    Jun 21, 2004
    3,700
    137
    Middle Earth
    +608
    On a PW6 you'll need to use component as the DVI card does not do 50Hz (PAL) at the HD resolutions of 720p or 1080i only 60Hz (NTSC). This was a problem with the PW6 with DVI (PW6 is not compatible with the G7 HDMI card) and the PW7 with DVI or HDMI. The PW8's should have it sorted with DVI/HDMI but that's of no conciliation to you.
  5. whitestripes
    whitestripes
    Component it is.
    Thanks! :D
  6. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,175
    Norwich
    +795
    Plus you have the added bonus on the 6 series of inputting that on the VGA input.
  7. GranPremio
    GranPremio
    ...for what it's worth, many people, myself included, prefer the analogue (component) picture on the Panasonics. I have a 50PHD7 with both boards and like for like would opt for component instead of HDMI.
    SKY is not a problem, there will be component on the early boxes. More of an issue may be DVD HD (or Blue Ray) which will likely NOT have component. They may however universally adopt 60Hz in which case you will be ok, or if that fails there are plenty of DVI/HDMI to VGA adapters on the market!!
    ...so many options......
  8. whitestripes
    whitestripes
    Ah yes, DVI/HDMI --> VGA would make more sense, seeing as how there wouldn't be need to purchase another Component board. However, what is the picture quality like with the VGA compared with the Component connection?
    Edit: After reading around, it appears a component connection would deliver a noticeably better picture than using a HDMI/DVI-->VGA conversion box etc. Hmm, might just get both lest Sky, or at least the television companies, decide to ditch an analogue component connection for HDTV because of the lack of HDCP...
  9. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,714
    The Borders
    +3,077
    whitestripes
    That last post was mighty confusing :)
    DVI-D and HDMI are Digital video connectivity standards - HDMI also has the ability to transmit Audio.
    YUV and RGB are video signals that can be transmitted over Analogue or Digital interconnects.
    Your Display has an Optional DVI Input Board - though its pretty restrictive for UK/Euro system owners as whilst it works with a decent range of 60Hz signals it only works with one 50Hz signal(576P).
    Your Display has a built in HD15 (VGA) socket that will work with Interlaced and Progressive YUV and RGBHV analogue signals; you require a suitable adapter cable to input YUV into this socket (see http://www.avforums.com/forums/showthread.php?t=185776)
    Inputting a YUV signal into the HD15 (VGA) socket is indistinguishable from inputting YUV via the Optional YUV Input board.
    SKY have said you can have Analogue YUV (via 3RCA) and Digital RGB (Via HDMI) from the as yet unreleased SKY HD Digibox - though the YUV outputs may offer a limited service as content owners may choose to only output some content on the HDMI sockets as its copy protected.
    Best regards
    Joe
