Compatible batteries question
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by w4yne, Jul 5, 2004.
  1. w4yne
    w4yne
    May 9, 2004
    40
    Wales
    Do any of you use the compatible batteries that can be found on ebay etc for less than £20 and if so how do you rate them , good or best left alone ?
  2. w4yne
    w4yne
    May 9, 2004
    40
    Wales
    So do you all buy original manufacturers replacement batteries then ? no one got a Hahnel or similar ?
  3. Brian110507
    Brian110507
    No I certainly do not buy only the expensive original equipment ones but you specifically said on e-bay so perhaps not many of us buy batteries that way.
    I personally buy all my camera and camcorder batteries from www.keene.co.uk but there are dozens (if not hundreds) of cheap online retailers which are all very good. I just wouldn't trust an unknown seller on e-bay.
    In over 10 years I have never had a problem with anything which I bought from Keenes.
  4. w4yne
    w4yne
    May 9, 2004
    40
    Wales
    I said
    The important bit being the etc on the end but thanks for the info on Keenes :thumbsup: and if as you say you are happy with all you have bought off them in 10 years then it will probably be better for me to pay another £10 on top of the ebay prices for the same spec battery off them.
