Compatibility of Philips DTR500 remote
Discussion in 'Satellite TV, Sky TV & FreeSat' started by DRowe, May 9, 2005.
  1. DRowe
    DRowe
    I purchased a Philips DTR500 receiver and 14PF7846/12 LCD TV last week.
    Being from the same manufacturer I had hoped to be able to use just one remote. The Freeview receiver instructions say that this should be the case, but it does not seem to work in practice.
    I tried to change the default Receiver remote channel from 39 to 38 to see if this worked, but an error in the user manual led to me locking myself out of the receiver! Thankfully, this forum came to my rescue and gave the correct codes to reset the remote to 39!
    I haven't retried the change to remote channel 38 as I don't won't to lock myself out again. The receiver is great, but Philip's customer support was hopeless and had no clue about this.
    Are the TV and receiver remotes incompatible - can anyone help??
    Also have a Sony DGX500 which is a joy to use and has a programmable remote that I can use with my JVC telly!
  2. jmscott
    jmscott
    Mar 13, 2005
    Dear Drowe,
    I noticed you mention you tried switching your DTR500 remote from 39 to 38 and managed to lock yourself out. Well I have managed to exactly that, as well and the manual doesn't seem to help. Could you send me the fix that got you out of this pickle ? My email address is j_m_scott@yahoo.com
    Thanks, John
