I was able to try out an AVCHD-BDR disc in a number of Blu-ray players in an AV shop today. The sample AVCHD-BDR had been burned using my DMR-BWT700 and the AVCHD files were shot on a Panasonic X900 camcorder in 17Mbps mode (1080/50i).
Nothing approaching scientific method was possible since only certain machines were connected up to screens, but here are the results, in case anyone else finds themselves in a similar situation:
1. All Blu-ray players that I tried from Sony, Panasonic and Samsung played the AVCHD-BDR without problem (i.e. smooth playback, scan, chapter skip, disc menu with titles etc). Machines from other makers were not connected so I couldn't try the likes of LG, Toshiba etc.
2. However, the lower-end Panasonic players (£100 or less) produced an initial menu screen that suggested the machine would not play back the AVCHD-BDR. It was only after navigating through a couple more menus from that initial menu (none of these were at all intuitive) that I could access the contents of the AVCHD-BDR. Panasonic players from about £180 upwards recognised the AVCHD-BDR right away and brought up the disc's own menu.
3. Sony players of all types (budget and more expensive machines) recognised the AVCHD-BDR immediately and brought up an option to show the disc's menu.
I downloaded the manuals for a couple of lower-end Panasonic Blu-ray players and these would imply that the machines would play AVCHD-DVDRs but not AVCHD-BDRs. However (as noted above), this was not the case, but accessing the AVCHD-BDR required some heavy lifting on these machines (after which disc playback was fine). By contrast, I noted that the cheapest Sony machine of all sported an 'AVCHD' sticker along with the customary ones trumpeting web functionality et al. So it appears that Sony make more of the AVCHD playback capabilities of their Blu-ray players than do Panasonic.
I should stress that this test was far from exhaustive and anyone interested in AVCHD-BDR playback on standard Blu-ray players should try to test any machine in advance. In my case I was looking for a Blu-ray player for a relative and, given that ease of use (with AVCHD-BDRs) was a essential, I bought a Sony.
ClassicalMan
