compatibility issues for dvd-rw drive
Discussion in 'Desktop & Laptop Computers Forum' started by edrock85, Sep 7, 2004.
  1. edrock85
    edrock85
    Hi, I recently bought a sony vaio pcv-v1 with a mat****a UJ-810 DVD-RW drive built in and was looking for some advice as to where I could find out which blank dvd-r's and dvd-rw's I could use to burn video onto. I really don't want to buy a spindle of discs that don't work with it, thanks, Ed
  2. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    My Packard Bell laptop has the same Matsush.ita UJ-810, I've not had any problems with any of the blank media that I have used. Here's the brands and formats that I have used:
    DVD-RAM: Panasonic (No surprise there then as Panny are part of Matsush.ita).
    DVD-RW: Golding AQ.
    DVD-R: Verbatim, Maxell, Mr. Data & unbranded discs.
    Hope that helps, I usually get my blank media from Maplin but I'm sure you'd get cheaper if you bought online, I prefer to buy locally.
    S.
    p.s. The drive works with CD-R & CD-RW too.
  3. Harry T2
    Harry T2
    Jul 29, 2004
    482
    +10
    You will probably get a better response in one of the other forums here.
    There is a lot of information here
    Haven't used the burner you have, but never had a problem using RitekG04 disks, in burning or being read on a variety of players.
  4. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    23,117
    2
    In a secret location with Jennifer Lawrence
    +10,006
    Moving to computer hardware forum
