Compatibility between Pronto 940 and Marantz 5000i
Discussion in 'Home Cinema Control & Remote Controls' started by mickl, Nov 2, 2004.
  1. mickl
    mickl
    Sep 10, 2002
    1,314
    48
    +28
    hi
    I'm just querying if the ccf config files on a Pronto 940 is directly compatible with the Marantz 5000i or does it need some for of conversion for it to work?
    thanks
  2. Loada
    Loada
    Mar 4, 2003
    592
    Guisborough, North Yorkshire
    +51
    They are almost directly compatible. There are slight firmware differences (beeps on the Pronto, page jumps on the Marantz etc) but if I remember correctly, the respective programming softwares will load CCFs from the other unit and will just ignore the "differences".
    Might be worth checking out the forums on Remote Central to confirm (you might have to search back in the archives a bit!).
