Compatablity of (HDCP) HDMI DVD output to DVI PJ
Discussion in 'Blu-ray & DVD Players & Recorders' started by Starkiller, May 11, 2005.
  1. Starkiller
    Starkiller
    Nov 3, 2003
    202
    +3
    Im looking a 2 DVD players Arcam 79 and the Denon 3910 to conect to my existing themescene H56
    I wanted to connect digtally via DVI or HDMI with dvi convertor
    The PJ is capable of HDTV, but ive been advised that both the 79 & 3910 players use HDCP output(if i understand this correctly) and is not compatable with the DVI input on the themescene.
    Can this be fixed or worked arround so i can get a digtal signal in to my PJ?
    :lease:
  2. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    If your Themesecene does not have HDCP there is no workaround - sorry. HDCP is a copy protection algorithm which is mandatory on the HDMI or DVI outputs of DVD players. You could talk to the PJ maker to see if they can help; it's very unlikely but you never know.
    Otherwise use the component input of the PJ; it will still give a very decent picture from either of these DVD players.
    John Dawson (Arcam)
  3. Starkiller
    Starkiller
    Nov 3, 2003
    202
    +3
    Thanks for the reply, not what i wanted to hear but least i know.
    I will ask my retailer if the H56 can be "flash upgraded" or modified, my guess is no, but its worth asking.
    I guess i will have to go componet
    Its a shame when copy protection gets in the way of quality. Im sure if someone wanted to copy a disk they would just use a PC.
  4. Phil Harris
    Phil Harris
    Might be a silly question, but I shall ask it anyway....
    Is the HDCP protection applied to all material played, or only to material with it built in?
    For instance, I have a TV with a DVI input, if I was to buy an HDMI DVD player, would I be able to play DVD's from my current collection, none of which have any protection on them?
    I would be interested to use a purely digital interface between DVD and TV, so should I look for a player where the HDCP can be turned off (Samsung 745)?
    Thanks in anticipation...
    Phil.
  5. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    HDCP is usually applied when the DVD "asks" for copy protection to be applied, so your home movies should work OK with a non-HDCP DVI connection. Under these circumstances Macrovision analogue copy protection is also usually turned off.
    HTH.
    John Dawson (Arcam)
  6. Starkiller
    Starkiller
    Nov 3, 2003
    202
    +3
    John
    This HDCP is fustrating, having spent £3000 on a PJ and screen last year and now needing to upgrade cuz its not got the industrys "lastest brain wave" is pretty rough.
    Im reluctant to spend £1000 on dvd player and not be able to uses its main feature.
    reading thu your 79's manual, I see there is a option to switch Output priorty to Analogue from HDMI/DVI, if this was selected can you use a hdmi/dvi lead but get an analogue signal?
    Dave
  7. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    There are other DVD players around where the HDCP can be turned off, so unless you have your heart set on the Arcam or Denon then there are alternatives...PJ :)
  8. Starkiller
    Starkiller
    Nov 3, 2003
    202
    +3
    I had got my heart set on the arcam(I wanted a matched pair with the AV300 amp), but im open to suggestions.
    can you say what the Alternatives are, i guess one is in your signature
