tuckerdognc
I'm trying to decide on getting the LG C1 or Samsung NQ90A while they are on sale ... I've done quite a bit of research and it took a lot to narrow down to these choices. I read info regarding the brightness (good for bright rooms) but is the NQ90A good for dark rooms?
We currently sit looking directly into the 13 yr old Panasonic 50" plasma that I want to "just simply" upgrade to a 65" and the choices and info is maddening. Occasionally, watch some tennis or something from the side (if guests or working at a desk toward the side). How is the NQ90A for 50% angle? I could fix with a swivel (like the one that is built into the Panasonic).
And brightness... comparing the Plasma, I want some good blacks ... how does the Samsung compare? And I understand the OLED (LG C1) is great with blacks, but I'm concerned about burn in and glare (though I've never had burn in with the Plasma...
We pay the "big bucks" to keep cable for the DVRs an to skip commercials. We often will pause a tennis match, for example, 30 minutes to get past commercials and zip thru the match. It sounds, here, the Samsung is ahead.
During the day there is a window very near the tv and at an angle, 45 degrees. There are times we pull the curtain if necessary but it's very rare. I assume the Samsung isn't as reflective, so it seems it would do better there, correct?
I wish I could just purchase $1600 tvs on a whim... but, for example, the Plasma is 13 yrs old and it's been great. Just want a bigger screen... can you help?
