Is there anywhere online I can compare side by side 2 Samsung TV's Samsung UE55MU6400 Samsung UE55H6200 I know 1 is 4k and the other isn't, but 4k wouldn't be my 'main' viewing, so don't want to get suckered into it. Thanks
It is quite hard to compare TVs from different generations. The MU6400 is a 2017 model whilst the H6200 is from 2014. What are you currently using and what quality will your sources be? Maybe we can help you with recommendations? Should I upgrade? - UHD vs FHD My best value TVs, 2017 Edition
I'd probably keep with what you have then. A good time to upgrade if you mainly watch Sky would be when they introduce HDR. Unless you can view close enough to benefit from UHD and have UHD channels. The problem is by going UHD you make poorer quality channels look worse for the sake of the better ones looking good. There are more suitable upgrades than the MU6400 too, all are listed in the guide. Plus you may want to consider a larger TV if you can fit it.
