Compare Marantz SR4500 with Denon AVR 1905
Discussion in 'AV Receivers & Amplifiers' started by pippo33, Jul 12, 2005.
Tags:
  1. pippo33
    pippo33
    Dear all,
    I am supposed to buy an amplifier as a present to a friend.
    After several analysis, considering price and what my friend like, I reduced the choice between 2 possibilities: the Marantz SR4500 and the Denon AVR 1905.
    My friend needs an ampliefier to set up an home theater but he is also a music and Hi-Fi fan, therefore I would like to buy something that then matched with the proper speakers, can work as a good hometheater and as a very good Hi-Fi.
    Does any of you can help me to make this choice??
    Which are the main differences between the 2 amplifiers??
    Pippo
  2. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    They seem reasonably well matched on paper and looks. My instinct tells me the Denon is better with music but that is not to say the Marantz is bad. It may come down to availability and in that respect it may have to be the Marantz because some have posted difficulty obtaining 1905's due to them being 'end of line'.
  3. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    I think it's the other way around...
    In real world prices Marantz are one of the most musical AVReceivers, with NAD, Arcam, Rotel...
    Denon are great machines, but not as musical.
  4. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    I must have a listen to one then. I said instinct because I have not read too many converted audiophiles singing Marantz's praises, while I read a lot of positive comments about Denons musical abilities. I think my Denon would be hard to beat for what I paid, but then it gives me some comfort to do so! :)
  5. Astaroth
    Astaroth
    Jun 22, 2004
    3,653
    2
    London
    +882
    From personal experience (having owned both Marantz and Denon systems) I would agree with Falp that the marantz is better musically but the denon is better at HT work.
    My personal driver was for HT as I have a seperate hi-fi system and therefore currently have a Denon AVR2805. It certainly isnt BAD at hi-fi but there are others out there that are better.
  6. pippo33
    pippo33
    Hi again,
    it seems opinions are different.
    Yesterday I visited a famous shop in Rome, very advanced in selling Amplifiers, HI-Fis and HT. Also there it seems opinions are different.
    The one I heard yesterday is that Denon has a higher current, and even if power out is same for both 80W, for Hi-Fi purposes the higher current would make the difference in the sound.
    What do you think??
    Pippo
  7. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Forget it... the Marantz can get around 5x80w real watts, I doubt if the Denon can get 5x50w...
    Have a look at any review measurement...
  8. pippo33
    pippo33
    I was not talking about power, but current.
    What I was told is that Denon has more current and this is giving a better sound.
    Regarding power, the 2 technical notes say they are both 7 channels for 80W.
    But if you tell me this is not reality, I believe it
    Pippo
  9. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    The same for current I think...
    But take a look at same reviews measurements... like the ones from homecinemachoice online
    The problem is that each amp can get that power, but not simultaneously... :rolleyes:
  10. pippo33
    pippo33
    I went to homecinemachoice, but I couldn't find the 2 specific model, Denon 1905 and Marantz 4500
    Do you know where to find reviews about them??
    Thanks a lot
    Pippo
  11. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Take a look at the 1604 and 4400, or the new 5500 and 2105 reviews.
    They have the same amps of current models, only diferent processors...
