jimmurrin
Trying to buy a projector for XMAS. Here are the specs:
Room: 12.5 ft to 107" diagonal screen
Reasonably controlled theater room (dark grey walls, covered window)
Input: XBOX One (streaming movies and games) and TV antenna (sporting events)
Desired priorities:
1) Movies
2) Gaming
Looking for a "short term solution" until 4k really blossoms. Have whittled down to either the Optoma 142x or HD27. Both are priced the same. Reading through reviews the specs appear to be very similar, so can't tell the difference.
What would you recommend?
Desired priorities:
1) Movies
2) Gaming
