compaq IPAQ 3835
Discussion in 'Mobile Phones Forum' started by The Foot, Oct 22, 2005.
  1. The Foot
    The Foot
    Dec 17, 2004
    289
    16
    Has anyone used one of these? If so can you give me some advice as to whether you think they're any good.
  2. sbaddison
    sbaddison
    Oct 2, 2005
    359
    Warwickshire, UK
    +6
    Hi.
    I've got a similar iPAQ 3830 which is fine, basic PDA. Connectivity is poor (IR only, no bluetooth etc) but you can add on jeckets for that if you wife.
    I mainly use mine for GPS with a Navman 3450 voice jacket running SmartSt V2.
    My main gripe is battery life and the fact that there's no CAM battery :(
    Cheers,
    Simon
