Compact Digital with good Video Capture
Discussion in 'Photography Forums' started by Razor, Apr 4, 2005.
  1. Razor
    Razor
    Dec 15, 2004
    37,566
    2
    +12,432
    I am looking to get a small digital camera which will be used for general use.
    My main priorty is video capture. I want 30 fps at the best resolution. It must also have a underwater housing (case) avialible, to buy. The idea being to film fish whilst diving.
    I would like 5 x zoom and 5 megapixels and for it to be as small as possible
    I was looking at the Pentax Optio sv is it a good camera or could anyone suggest a better one.
    http://www.pentax.co.uk/product_details.php?divisionid=2&productid=1201&parentid=16
    Thanks in advance :)
  2. Razor
    Razor
    Dec 15, 2004
    37,566
    2
    +12,432
    Anyone????
  3. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,031
    48
    Reading, Berkshire
    +54
    Not 5x zoom and 5mp, but i'm sure Canon will do a similar spec model. My Ixus 30 works great underwater, just came back from the Whitsundays and have some really nice coral shots, saturation needed a bit of tweaking in PS, but other than that, great! Also does 640x480 video @30fps or 320 x 240 @ a whopping 60fps. Brilliant!
  4. Razor
    Razor
    Dec 15, 2004
    37,566
    2
    +12,432
    Cheers SeaneyC, that sounds very good. A lot better than the pentax. I'll have a look at the canon site :) Im off to the Rea Sea in a month :) Cant wait. Just looked up Whitsundays and it looks very nice. Have you got a lot of video footage and how long does a 512mg card give you?
  5. Razor
    Razor
    Dec 15, 2004
    37,566
    2
    +12,432
    Just been looking at the Canon Digital IXUS 50, it has the same 640 x 480 @ 30fps. :)
    This is just what I am looking for cheers. Only problem now is a underwater housing, I cant seem to find one. Any help would be great. :D
  6. T0MAT01
    T0MAT01
    Dec 25, 2004
    2,383
    113
    Devon, Sussex or somewhere inbetween.
    +552
  7. Razor
    Razor
    Dec 15, 2004
    37,566
    2
    +12,432
    Kiebler
    It sounds as if you work in Jessops :)
    Do you or any one know if there is an underwater housing for the Canon Digital IXUS 50. Also is this a good camera?
    Cheers :)
  8. ASH1
    ASH1
    Mar 1, 2003
    1,221
    +63
    Hi Razor, have a look at the Canon S70. and I did see a under water housing for it a while ago on www.7dayshop.com
    ASH1 :smashin:
  9. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,031
    48
    Reading, Berkshire
    +54
    The ixus 50 takes the same case as my Ixus 30, the AW-DC30, which is waterproof to 3m. I picked it up in Australia for about £65 i think, you can probably it on Ebay or similar. You can do everything with the camera in the case you can do with it out of the case, which is handy (apart from change memory card or battery obviously!)
  10. Razor
    Razor
    Dec 15, 2004
    37,566
    2
    +12,432
    Cheers for link but the site only has fuji housings, or am I missing it completely and I really want the canon 50 if poss. :(
    Seaney C
    Thanks for tip on the canon 30. 3 m isnt really deep enough as I intend to dive with the camera, I will try ebay though :)
  11. ASH1
    ASH1
    Mar 1, 2003
    1,221
    +63
    Hi Razor, look under Canon Digital Camera Accessories. You will find them there.
    ASH1
  12. Razor
    Razor
    Dec 15, 2004
    37,566
    2
    +12,432
    Found it. Cheers ash. No case for diving with canon ixius 50 :(
  13. ASH1
    ASH1
    Mar 1, 2003
    1,221
    +63
    You could always send them a email asking if they can get you one.
    ASH1
  14. Razor
    Razor
    Dec 15, 2004
    37,566
    2
    +12,432
    Good idea I will give it a try. :)
  15. kiebler
    kiebler
    to razor. i do work for jessops. i spoke to our help desk. ixus 50 housing is £99.99 but only goes to 3m. there is no indication that a non canon product will produce one that will go further. ixus 50 only arrived today in my store so not tried it yet
  16. Razor
    Razor
    Dec 15, 2004
    37,566
    2
    +12,432
    Kiebler
    Many thanks for the info. Can the Canon 50 fit in a canon 30 housing?
    Really appreciate the help :smashin: Cheers.
