Hi all, I know this question has been asked so many times but there is so much different information I am looking at what the best speaker setup is for my small sized cinema room.
The room is approximately 3m x 4m, the sofa is positioned 20cm away from the wall (as far as the wife would allow it), the viewer will seat approximately 3m away from the screen. I currently have is setup as 5.1 as follows:
AV Receiver = Denon avr-x2700h
Front left & right + centre channel = Monitor Audio in wall speakers WSS230
Surrounds = Cambridge Audio Minx 11
Sub = REL Acoustics Quake
So I want to expand the system, with a bit of work I can add some speakers in the ceiling for 5.1.2, reading lots of views not sure if it is worth it, a lot point to Atmos requiring 5.1.4 to really notice the different which in my room layout cannot be achieved. Another option is 7.1, but again if I understand correctly the sofa needs to be at least one metre away from the wall to properly achieve this? Are there any achievable work arounds to achieve 7.1 providing an improvement over 5.1, speakers behind the sofa on the floor pointing up, more in wall speakers behind the sofa, speakers higher up etc. Or is the best I can achieve with this layout 5.1.2?
I currently have the option to upgrade the amp as it was only recently purchased to the Denon AVC-X3700H which would allow the extra channels for 7.1.2 but do not want to spend the extra £400 if the layout is just not workable.
I look forward to knowing what people think?
