Common Interface on TV
Discussion in 'General TV Discussions Forum' started by benlwatts, Oct 11, 2018.
Tags:
    1. benlwatts
      benlwatts
      Oct 11, 2018
      2
      Bristol
      Hi All,
      Firstly hope I've posted this in the right forum and secondly I was hoping someone would be able to explain just how and what the common interface slot does on the back of my TV. Would I be right in thinking you could add specific viewing cards to it lets say for foreign channels ?
    2. mike7
      mike7
      Jan 3, 2005
      4,945
      Norwich
      +616
      It is for use in some countries where a subscribed card can be inserted to access the local cable TV system. It is of no use whatsoever in the UK as it does not allow access to Virgin Media cable.
    3. benlwatts
      benlwatts
      Oct 11, 2018
      2
      Bristol
      So I wouldn't be able to put a polsat card in it to pick up those channels ?
    4. mike7
      mike7
      Jan 3, 2005
      4,945
      Norwich
      +616
      No. Its for cable tv purposes.
    5. Fred Smith
      Fred Smith
      Apr 23, 2004
      2,218
      Reading
      +374
      Depending on the TV, country and service supplier, it may work for DTT, DSAT or Cable. You plug a suitable CAM into it. Used to be used for services like Top-Up TV in the UK.
    6. Fred Smith
      Fred Smith
      Apr 23, 2004
      2,218
      Reading
      +374
      Possibly if the TV has a satellite tuner and you have a suitable CAM and card.
    7. Fred Smith
      Fred Smith
      Apr 23, 2004
      2,218
      Reading
      +374
      No it's part of the DTT spec, hence why all DTT European TV should have it.
    8. mike7
      mike7
      Jan 3, 2005
      4,945
      Norwich
      +616
      Apologies. I was not aware the tv had a satellite decoder. You would be advised to check compatibility before purchasing card.
    9. Stupot43
      Stupot43
      Nov 21, 2000
      649
      2
      32
      Dudley, West Midlands.
      +81
      In Digital Video Broadcasting, the Common Interface (also called DVB-CI) is a technology which allows decryption of pay TV channels. ... The Common Interface is the connection between the TV tuner (TV or set-top box) and the module (CAM) that decrypts the TV signal.
