Comments on my proposed system please!!!
Discussion in 'Plasma TVs Forum' started by CraigHolt, Aug 1, 2005.
  1. CraigHolt
    CraigHolt
    Panasonic 42PV500, Pioneer DV575 DVD, Pioneer VSXC502 Amp, Mordaunt-Short Genie speakers
    After months of research (!) I am thinking of getting the above as my complete cinema package (plus cables etc). Will be approx 3k (2k plasma - totaldigital.biz, 1k remainder - richer sounds). I would really appreciate peoples' views before I take the plunge - particularly if anyone thinks there is a better set-up/choice of equipment I should go for.
    Thanks very much in advance,
    Craig
    (p.s. my main use is watching tv through my sky plus box, second main use will be watching dvds, I would also like to play my itunes through the amp/speaker system) :lease:
  2. CraigHolt
    CraigHolt
    Anyone?!
  3. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    it looks like a perfectly good solution to me....you may want to check teh speakers out in the speakers forum but personally I can't see there being any problems.
  4. CraigHolt
    CraigHolt
    Cheers mep. Was just looking for some final reassurance before I took the plunge! Ive probably spent enough for a new screen on various "what plasma" type magazines but they have only given me far to many options and left me even more confused than I was before I started!!
