Command and Conquer
Discussion in 'PC Gaming & Rigs' started by dolph, Oct 13, 2003.
  1. dolph
    dolph
    Dec 16, 2002
    1,191
    48
    +26
    Hello there,
    As I have a rather rubbish graphics card I was wondering can someone suggest the best Command & Conquer game to get. I know Generals needs a better graphics card than I have got but remember playing the first version of this game and loving it.
  2. Sinzer
    Sinzer
    May 25, 2002
    5,789
    +1,107
    What graphics card do you have?
    C&C: Red alert was most probably the best 2D C&C game, I would have a go at that one.
    Tiberian Sun is ok, but I found it quite easy.
  3. dolph
    dolph
    Dec 16, 2002
    1,191
    48
    +26
    I only have an onboard 32mb Geforce 4 - tried a mates C&C Generals and it was soo slow!!
  4. nathan_silly
    nathan_silly
    Should be OK- it plays reasonbly well on my 933mhz Geforce 2 MBX 32MB, only slows down during the large explosions (cut-scenes)
  5. dolph
    dolph
    Dec 16, 2002
    1,191
    48
    +26
    I'm pretty sure that I'd be able to get it passable (change quality settings etc), but just wondered if this game is up to the playability of the earlier ones - I'm a great beliver that as these games develop, they concentrate more on graphics and less on gameplay.
    If I bought one of the earlier versions of C&C can they be played online - and if so is there anyone around still playing the older versions?
  6. Sinzer
    Sinzer
    May 25, 2002
    5,789
    +1,107
    C&C Generals is at it's best online, the single player game is ok, but the game has really been balanced for online play.
    C&C Red alert 2 was the biggest online from the 2D series, so you may want to try that, Yuri's revenge the expansion pack wasn't out that long ago.
  7. Toole
    Toole
    I'd recommend picking up a cheap copy of Red Alert 2 and the expansion Yuri's Revenge - that should see you going for a good while. Amazon are selling RA2 on it's own for £7.99 - but shop around and see what you find.
    I used to play it on my laptop quite a bit, which is a p650 with only 64mb and an 8mb graphics card!
    Red Alert 2 had quite a few things going for it over previous versions, and in my opinion is the best 2D version of the game available - there's not a lot that you can do in Generals that you can't do in Red Alert 2 - it just looks better in Generals, obviously...
    Also, not sure, but I do hear that RA2 also still has quite a large online following - plus there's a great feature in the multiplayer that allows you to slightly customise your side with specific units depending on what nation you choose to play as - so for instance, if you play as the allies you'll get slightly different units if you choose America/UK/Germany - so several people can play using the same side but all have slightly different strengths and weaknesses. It's good stuff. :)
    Of course, you still have to put up with the stupidly cheesey Command & Conquer storylines and oh so bloody terrible live-acted cut scenes in between missions in the campaign - but then I guess it wouldn't be C&C otherwise would it? :D
  8. dolph
    dolph
    Dec 16, 2002
    1,191
    48
    +26
    OK thanks guys, looks like a trawl round the bargain buckets for Red Alert 2 (and maybe Yuri's revenge) is in order.
  9. z5461313
    z5461313
    Sep 18, 2001
    1,455
    +171
    It was a really good game Red Alert - I played it to the end
    But the graphics now do look a bit funny
  10. dolph
    dolph
    Dec 16, 2002
    1,191
    48
    +26
    To be honest the graphics in a game like this don't mean much to me - it's the playability.
    Graphics are great in Car racing / Golf that sort of thing but when it comes to strtegy I don't really car. I'm still a great fan of the old Populous / Syndicate / Powermonder / Sim City games (yes even the original Sim City!!!)
  11. Sinzer
    Sinzer
    May 25, 2002
    5,789
    +1,107
    The original SimCity was the best :)
    If you haven't played Starcraft, I would recommend that over C&C any day, by far the best 2D RTS.
  12. Toole
    Toole
    hehehe - amazing! :eek:
    I hadn't played StarCraft in years and recently had a hankering to play through it again - so I managed to track it down for a tenner on budget including the Brood War expansion pack (my original copy has long since vanished somewhere).
    So not long ago I spent a good couple of weeks playing through that again and I can confirm that it's still as good to play now as it was about 5/6 years ago (does look a bit old, but it doesn't affect the gameplay) :)
  13. HMHB
    HMHB
    Nov 11, 2001
    25,512
    Nottinghamshire
    +3,850
    And don't forget the classic Total Annihilation the daddy of them all. It's still playable today after all these years, although not graphically brilliant
  14. Toole
    Toole
    Oh yeah, that game had me hooked for ages...
    Arggh, damnit - gonna have to go dig out my copy of TA when I get home now :D
  15. Dave20
    Dave20
    tib sun was the best gameplay.. but i cant go back to it after playing generals.. the gfx on generals is so superior.. but i play wc3 now as the game play is much better than generals
    sim city 2000 rox.. with those megatropolis' which i dearly missed when i got a go of sim city 4.. no where near as good as the old 2000 version
  16. HMHB
    HMHB
    Nov 11, 2001
    25,512
    Nottinghamshire
    +3,850
    excuse my ignorance, but what's wc3 ?
  17. russraff
    russraff
    Aug 1, 2000
    2,313
    Newcastle
    +51
    wc3 = War Craft 3.
    I am in the Starcraft camp, here, stunning game, with a good story to it, too. I would closely followStarcraft by Red Alert 2. I remember laughing quite a bit at Red Alert 2 - it had a sense of humour, and didn't take itself too seriously. Total Annihilation is another goody, especialy the music for some reason - it was very well done indeed.
    Anyway, in answer to andrewdolphin's question, if you want a C&C game get Red Alert 2 (I even played this online - a rarity for me) but if you want the best, get starcraft with the Brood Wars add on pack.
    Russell
  18. SpliffCartel
    SpliffCartel
    Oct 30, 2002
    73
    Pontypool, South Wales
    +7
    Yes, Starcraft is still the daddy! Had a lan game fairly recently at a mates house and played a lot of brood war :). Another thing that impresses me about starcraft is the pre rendered sequences still look really cool after all this time.
  19. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    Just for your info I have a copy of Red Alert 2 and I just looked on the box at the recommended Spec (for what its worth): 266mhz processor - 64mb RAM - 2mb GFX
    I am sure your pc should just about cope! :D
  20. Vection
    Vection
    Mar 23, 2002
    129
    19
    Over there!
    Good to see that the old c&c games are still being bought! I wasted months of my life playing the original C&C and Red alert but they do look very dated now. I still regularly play red alert 2 and all of the c&c games still have a large following at westwood online.
    Andrew, I have played every C&C game online and each has it strengths and weaknesses but all are still popular online and there are always people playing at all hours of the day.
    Original C&C was the best for missions/ storyline
    C&C Red alert 1 was great for mods, maps and extra missions
    C&C Tiberium sun was not my favorite but worthy sequal
    C&C Red alert 2 was a good laugh and the most playable online
    C&C Generals has great 3D grafix but even online it has lost some of its 'personality'.
    Still all great games though, i'd hate to add up how much time i spent playing all these.:rolleyes:
