Comfort security systems
Discussion in 'Home Cinema Control & Remote Controls' started by wizbongre, Jan 31, 2004.
  1. wizbongre
    wizbongre
    Jun 24, 2003
    592
    Liverpool, Merseyside
    +63
    I'm just wondering if anyone has any experience of the security systems offered by Comfort
    I'm about to purchase a new house with a broken alarm system... As I work away a lot I want to make sure Er Indoors is safe whilst I'm away. I quite like the look of the Comfort system and its potential for expansion in the future.
    Anyone got any experiences/comments?
    Thanks.
  2. steev
    steev
    Oct 22, 2001
    236
    19
    Beds, UK
    The Comfort is a very powerful system. If you just want an alarm you may be better off with a deicated system. If you want X10 control, voice mail etc then consider the Comfort. I still haven't got mine set up exactly as I want. It's controlling the outside lights and some internal. It just takes some patience to work out the programming. The Yahoo groups are very good for getting information.
