Comet repair advice?
Discussion in 'TVs' started by weyland-yutani, Dec 28, 2002.
  1. weyland-yutani
    weyland-yutani
    Jan 11, 2002
    1,783
    +103
    my panny 28pl1 is going for repair next week because of interference on screen when using the front AV sockets. i also want them to stop the ghosting/bleed from the aerial socket in to the scart signal.
    right, what i want to know is, is it worth it?
    you can only see the faults in certain specific pictures/conditions and in all likelyhood they will say they could SEE no problem and send it back.
    can the ghosting/bleed fault even be fixed or is it a by product of the manufacturing process that CAN'T be fixed?
    if they can't/won't even fix the thing is it worth me sending the thing off?
    any engineers out there who can tell me if these faults are fixable?
    thanks
  2. weyland-yutani
    weyland-yutani
    Jan 11, 2002
    1,783
    +103
  3. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,896
    71
    50 Rue St Georges, Paris.
    +27
    Yes the problems you describe should be corrected to your satisfaction.
    If your tv is under warranty you may wish to seek a " swap-out " replacement.
    Have you checked your cables and connections too ?
  4. weyland-yutani
    weyland-yutani
    Jan 11, 2002
    1,783
    +103
    i've only had it 6 weeks. what is a 'swap-out' replacement?
    the thing is i'm sure the comet engineers will say they couldn't SEE the problem so there is NO problem. how do i get them do see a problem that has to be correctly identified under certain conditions, when i'm not there to show them?
    oh, and thanks very much for replying:)
  5. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,896
    71
    +27
    Engineer's will mostly agree a set is faulty without hesitation.
    They are delighted if a customer insists on a replacement as it is less hassle for them.
    You are definitely entitled to ask for a replacement, as your set is only six weeks old, don't accept a repair unless you are happy to do so.
    A " swap-out " is a term to describe exchanging faulty items, it's often how mail order dealers solve the problem of having no local service assistance. They simply ask customers to send it back for a new one.
    Having said all that, an engineer may resolve your problem by setting up and cabling attention.
