Combo DVD/CD-RW or not
Discussion in 'Desktop & Laptop Computers Forum' started by d_devani, Mar 12, 2003.
  1. d_devani
    d_devani
    I'm not sure which ones better a combo drive or 2 separate
    cd/dvd reader and a CD-RW unit
    I would have thought that having them separately would make copying cd's directly without placing them on the hard drive quicker, but a friend told me that the combo drive option would be quicker - now I am really confused.....
    Please Help:confused:
  2. Sgt.Colon
    Sgt.Colon
    I have seperates which for me is fine. I can't see how a combo would be quicker + you could have problems making a combo region free. I would say get seperates.
  3. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Mine is a combi and is fine.
    Pioneer 104
    Reads and writes DVD-R -R/W and CD-R -R/W
    Only need for two drives would be direct copying.
    I copied an enhanced CD to HDD the burnt it as a redbook compatible CDR
    Can't compare sound quality as I gave up exchanging it after a few goes, when I found out it was not a disc fault as such:mad:
