Combining two pre-outs into one.
Discussion in 'Cables & Switches' started by pwiles1968, Jul 14, 2004.
  1. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +9
    I currently have at home on demo a Roksan Candy MkIII Integrated amp, which I have only spent a little time with but am seriously considering getting, the only issue is getting this and the sub-out from my AV amp into the ASW with only two inputs on the ASW, I am considering using a ‘Y’ adaptor to combine the L & R into a single out, my only concern is that this is basically shorting out the L & R would this be an issue?
    The other question is where can I get a good but cheap ‘Y’ adaptor? I have seen this but it is a little expensive http://www.hificables.co.uk/Product...D/2378/v/68ec94d0-b318-4b19-903e-fa8f0cefa482
  2. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
  3. pwiles1968
    pwiles1968
    May 15, 2003
    773
    +9
  4. nikyzf
    nikyzf
    I think you'd be OK as the 2 channels are the same source impedance and they would simply sum to mono, but would it be possible to do this using the AV amp (in unity gain mode)? I'd prefer that option if was available.
  5. pwiles1968
    pwiles1968
    May 15, 2003
    773
    +9
    All kit including the AV amp would be off if I was listening in stereo, I wanted to be able to have different sub levels between stereo use and AV use, I was going to use the AV sub setting to do this.
