combining titles on panny e85
Discussion in 'Blu-ray & DVD Players & Recorders' started by arcamalpha, Oct 16, 2004.
  1. arcamalpha
    arcamalpha
    Apr 14, 2003
    71
    cheshire,england
    Can somebody talk through combining titles on the panny e85.
    Been trying by following instruction manual but no luck.
  2. HMHB
    HMHB
    Nov 11, 2001
    27,233
    Nottinghamshire
    +6,142
    Is this possible ? If so I really would like to know how to do it as well !
  3. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    You can't combine titles as such. However, you can create playlists and this works pretty well. Look for playlists in the manual. They're pretty easy to create and once you have a playlist of certain titles you can then dub to a DVD be it -R or -RAM.
    S.
  4. HMHB
    HMHB
    Nov 11, 2001
    27,233
    Nottinghamshire
    +6,142
    Aha, thanks. Do you notice the change from one title to the next when playing back then ? (ie is there a gap in playback ?)
  5. nwgarratt
    nwgarratt
    May 5, 2002
    27,477
    +3,117
    The only way to combine recordings properly into one recording is to use Panasonic Movie Album. It comes with Panasonic RAM drives.
  6. ben223
    ben223
    Try this:
    Let's say that you have two titles that you want to combine.
    Create a Play List. Add both titles as chapters in the Play List. Press Return to get to Play List View. Press Sub Menu then Chapter View. 001 will be highlighted. Press Sub Menu again then Combine Chapters and then Confirm. You will have a Play List with both titles combined which you can dub to dvd
  7. Nelviticus
    Nelviticus
    Jun 21, 2003
    474
    Hitchin
    +69
    I suppose that you could dub the playlist to a RAM disk and copy it back to the HDD, resulting in a single recording. Never tried it but I reckon it would work.
