Combine two toslink (optical audio) sources into one input.
Discussion in 'AV Receivers & Amplifiers' started by BuggSuperstar, Feb 19, 2014.
  1. BuggSuperstar
    BuggSuperstar
    Feb 19, 2014
    I would like to combine two toslink (optical audio) sources into one input without using a switcher where I have to get up off of the couch. I swear I am not lazy, I just crave efficiency.
    I believe I can use a Y-splitter for breaking up a single toslink signal to two inputs, but just use it in reverse? Obviousley only once input device could be on at a time or I will hear a terrible noise.
    Can anyone confirm this works? Even better, can anyone point me in the right direction to a product?
    Thank you very much for your help! I hope to return the favour one day...but it definitely won't be in A/V :)
  2. stevelup
    stevelup
    Aug 13, 2002
    6,793
    Swindon
    +1,293
    If your devices actually turn off the emitter when they are off, then you can use a passive splitter. Lots of units leave it powered continuously though.
  3. dante01
    dante01
    Mar 5, 2009
    46,087
    +11,044
