Combi-Drill Battery Advice
Discussion in 'General Chat' started by nheather, Jun 25, 2015.
  1. nheather
    nheather
    Oct 6, 2004
    20,162
    167
    Horsham, West Sussex
    +10,522
    Buying myself a new combi-drill.
    I'm happy choosing the drill, just need some help with batteries.
    I will definately be going with 18v Li-Ion.
    The question is capacity and how many.
    I am an infrequent DIYer. Let's say I use a drill four times a year and then mostly for short durations.
    With the cheap Ni-Cad drills I have owned before I am used to the battery being flat when I come to use it, so work always starts with a charging session.
    This leads to my first question - in my situation is there any benefit to having two batteries.
    Next question 2.0A or 3.0A. Clearly the 3.0A will last longer and will be heavier. But what does that mean in real world terms. Also consider that whilst my jobs may be short they sometimes involve drilling into masonary.
    Cheers,
    Nigel
  2. WeegyAVLover
    WeegyAVLover
    May 3, 2007
    4,923
    Scotland
    +1,984
    Nigel
    First off I am a fan of the Hitachi drills, more affordable than Makita and Dewalt but just as good (in my humble opinion), I know you did not want this advice but I am going the extra mile.
    If you are that infrequent then the size of the battery is less important, however I would always advocate going for a 2 battery solution, even if you are infrequent user you could be in the situation where you are doing a lot of work during your infrequent uses to the point the one battery you have goes flat and then you have to wait for that battery to charge.
    As for battery type, Li-Ion battery ones I have retain their charge well and a 2 x 2.0A is probably more than good enough for your needs, again IMHO.
    That said you can pick up some good deals on NI-CAD drills, but they are a lot heavier than Li-Ion
  3. ldoodle
    ldoodle
    Apr 2, 2005
    6,568
    +1,018
    I have a Bosch 18v Combi, with 2X 1.3Ah batteries. They take 15-20 minutes to fully charge so despite the shorter run time, I'm never out.
    The run time is not stupid either.
  4. 27neth
    27neth
    Feb 15, 2007
    3,518
    middlesbrough
    +1,346
    Buy a corded drill.. If you hardly use it.. A lot more power than a diy battery drill..
    John..
  5. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    24,635
    2
    In a secret location with Jennifer Lawrence
    +12,096
    Depends on your budget. For about £170+VAT you can get a Milwaukee battery drill which is superb quality.
  6. 27neth
    27neth
    Feb 15, 2007
    3,518
    middlesbrough
    +1,346
    I wouldn't buy Milwaukee, 2 of the joiners I work with both got the 18v impact and drill kit. Both sets have been back for repair countless times in the first year.
    John..
  7. Greg Hook
    Greg Hook
    Nov 25, 2001
    24,635
    2
    +12,096
    They must have been unlucky there. I've got about 10 Milwaukee drills used constantly all during the day at work here and they don't give any problems at all.
  8. WeegyAVLover
    WeegyAVLover
    May 3, 2007
    4,923
    Scotland
    +1,984
    John makes a good point - a cheap corded drill maybe more useful and a hell of lot cheaper if all you are doing is drill holes, especially in brickwork.
  9. jenam93
    jenam93
    Nov 5, 2002
    3,706
    +1,081
    I third the motion for a corded drill.
    Splashing out on a combi drill and 2 batteries for use 4 times a year just is not worth it.
    The batteries on the cordless will probably be dead in a few years then you'll either be looking for expensive new batteries, or expensive new cordless and batteries again.
    The corded drill will be good for years to come.
  10. stephenbarnes
    stephenbarnes
    Sep 18, 2013
    4,872
    +846
    I just junked my old 14.v nimh drill bought a 10.8v lithium for £25. The pack is only 3 x 18650 cells in a easy to solder pack, the old one had 12 cells are tightly bundled together- a nightmare to de-solder and re-solder.
    Mains drill is a must when you're going into steel or masonry, they have far more torque.
  11. jonna
    jonna
    Mar 25, 2002
    3,271
    Cheshire
    +2,762
    I thought we were drilling not soldering.
  12. nheather
    nheather
    Oct 6, 2004
    20,162
    167
    +10,522
    Thanks, some varied advice there.
    For info, I am looking at a Bosch (blue - professional) that is about £100 with 3A battery.
    There is one with a slightly different number but it is the same drill with two 2.0A batteries for £150.
    However, you can get a 3.0A battery for £50 so the I can get the drill with two 3.0A batteries for £150.
    So same price for two 2.0A or two 3.0A. Seems a no-brainer but just checking that the 3.0A batteries don't make it heavy and unweildy.
    Or I can get it with just one 3.0A for £50 less.
    BTW - already have a corded drill - just want the additional freedom of being able to move around with the drill.
    Cheers,
    Nigel
  13. stephenbarnes
    stephenbarnes
    Sep 18, 2013
    4,872
    +846
    talking about battery pack inside the drill...
  14. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,991
    2
    The Fylde Coast
    +13,936
    Have you links to the ones you're thinking about? I'm going through the same deliberations!
    A nephew of mine is a chippy and he reckons the 10.8V Bosch Professional range with the combi drill and an impact driver is the mutts nutts. (linky) The 10.8V is apparently shorter than the higher voltage drills and as such it will fit inside a 300mm kitchen cupboard to screw on the hinges and doors.
  15. clc.sheff
    clc.sheff
    May 28, 2008
    3,560
    Steel City
    +1,874
    I sell power tools.
    Always 2 bats if poss and 2.0 Ah is more than likely plenty for your usage for 18v.
    P.s. Check out Bosh Karat or Bosch multi constructor drill bits
  16. nheather
    nheather
    Oct 6, 2004
    20,162
    167
    +10,522
    I went for this one in the end
    Bosch GSB 1800 18V 3Ah Li-Ion Cordless Combi Drill | Cordless Combi Drills | Screwfix.com
    with an extra battery pack
    Bosch 18V 3.0Ah Li-Ion Coolpack Battery | Batteries & Chargers | Screwfix.com
    So £150 in total.
    I did deliberate over this one in store.
    DeWalt DCD776D2-GB 18V 2.0Ah Li-Ion Cordless Combi Drill | Cordless Combi Drills | Screwfix.com
    It's a bit cheaper at £140 but has 2.0A batteries though I am sure that they would be more than I would need.
    Handled them both in the store - the Bosch felt smoother and better built. The Bosch is shorter, which is not a big deal to me but will be for some. The Bosch is more powerful on paper 67Nm versus 48Nm.
    I won't be using it for a few days so if anyone thinks I have made a bad choice please shout out because I can change it.
    Cheers,
    Nigel
  17. simonlewis
    simonlewis
    Jul 31, 2014
    4,707
    stockport
    +1,760
    It's an expensive screwdriver, i noticed it has't got a hammer drill for drilling into masonry.
  18. stephenbarnes
    stephenbarnes
    Sep 18, 2013
    4,872
    +846
    Bought one of these, £25.
  19. nheather
    nheather
    Oct 6, 2004
    20,162
    167
    +10,522
    Yes it does.
    Cheers,
    Nigel
  20. simonlewis
    simonlewis
    Jul 31, 2014
    4,707
    stockport
    +1,760
    Okay apologies, my bad. :smashin:
