Colours look washed out (more green)
Discussion in 'Playstation Forums' started by LEEMJONES, Apr 24, 2007.
  1. LEEMJONES
    LEEMJONES
    Apr 12, 2005
    302
    +8
    I have noticed a few times that after a while playing a game or watching a film on my PS3 the colours go weird. For instance, when I am playing F1 the blue of the Renault turns pale green and the reds go pale orange!!!!
    If I restart the PS3 all is fine but this is annoying me now. I am using a component cable which I used on my PS2. Anyone else noticed this?
  2. stu.artd
    stu.artd
    Jul 29, 2005
    3,895
    +333
    I would reseat the connections and then if at all possible try a different cable to rule that possibility out.
    There is a chance that the graphics card in the PS3 is faulty, and if this happens as a game progresses then that would increase the chances of this being the case. Is there any on screen corruption at all ?
  3. leamspaceman
    leamspaceman
    Jun 22, 2004
    7,848
    +4,317
    I'm having this problem too! Did you get it sorted?
  4. leamspaceman
    leamspaceman
    Jun 22, 2004
    7,848
    +4,317
    Sorted...switched to official component cable.
  5. Croftanator
    Croftanator
    Sep 7, 2005
    92
    11
    My test PS3 at work does this. I have to use sticky tape to keep the cable in place :rotfl:
