Coloured lines on screen with DVI
Discussion in 'Computer Components' started by chrisbaker42, Jan 12, 2008.
  1. chrisbaker42
    chrisbaker42
    Apr 8, 2005
    1,645
    48
    Near Lampeter
    +96
    I have a Saphire X1550 PCI-E graphics card and have just got 20" Viewsonic monitor and I now have coloured lines flashing across the screen particularly noticable when using VMC. I noticed this before when outputting DVD's to my plasma over DVI, I have never noticed it over VGA. Is it a graphics card problem as I have already tried different leads?
  2. chrisbaker42
    chrisbaker42
    Apr 8, 2005
    1,645
    48
    Near Lampeter
    +96
    As an update to this, the lines are always horizontal and appear far more frequently if I am doing graphics dependent things such as using VMC to either play music with a slide show, show a DVD or when using photoshop to edit large files.
  3. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    plug your display into the other output on the graphics card.
  4. chrisbaker42
    chrisbaker42
    Apr 8, 2005
    1,645
    48
    Near Lampeter
    +96
    The other output is VGA, this is not a dual DVI card.
  5. chrisbaker42
    chrisbaker42
    Apr 8, 2005
    1,645
    48
    Near Lampeter
    +96
    I seem to have significantly reduced the problem by changing DVI settings in ATI catalyst to Reduce DVI Frequency on high res displays and the Alternate DVI operational mode. Perhaps this seems to suggest a better graphics card may be the solution. For a relatively cheap alternative would the ATI 2400XT or 2600Pro be suitable?
  6. Sukh88
    Sukh88
    Jan 1, 2008
    250
    28
    London
    +25
  7. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    All the ATi 2xxx series have the same problem, on the 2 rear sockets, one has a slightly "out of spec" output which certain monitors don't like. Getting a new card may not cure the problem (I know I tried it). Of course getting a new ATi card with dual DVI sockets will cure the problem, as you can use the working DVI socket.
  8. chrisbaker42
    chrisbaker42
    Apr 8, 2005
    1,645
    48
    Near Lampeter
    +96
    As this problem either has now dissappeared or at least is no longer noticeable is there anything to be gained from upgrading the graphics card as I do not use the machine for gaming but mainly editing large photographic files and occasionally watching DVD's.
