Coloured Cases
Discussion in 'Xbox Forums' started by Pooon, Sep 22, 2005.
  1. Pooon
    Pooon
    Dec 26, 2002
    7,367
    Canterbury, Kent
    +962
    i have a 'spare' xbox and would like to put a different case on it so where would you modders out there recommend to get one? and how hard is to remove the guts from one box to another(once all outer screws are removed, i do know about the ones under the stickers!)
  2. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    have you done anything like this before pooon?
    Gary
  3. Pooon
    Pooon
    Dec 26, 2002
    7,367
    Canterbury, Kent
    +962
    Not really, i've opened up my xbox before, and i've upgraded pc's n stuff
  4. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    modern PC's are like lego they used to require skill once to take apart these days most of them can be done with a spoon.
    The xbox isn't that difficult to take apart. but it can be fiddly. do a search on the some modding site and you'll find a diagram on where the screws are. take out the HD, DVDdrive and you can see the bottom. remove the motherboard screws and you should be in business.
    what case are you using as a replacement? are you doing this because you need too or because your bored?
    Gary
  5. Pooon
    Pooon
    Dec 26, 2002
    7,367
    Canterbury, Kent
    +962
    I'm doing this as i'm bored!!!! and i'd like some suggestions on where to get cases from as all the sites seem to be american whenever i search for them
  6. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    so hopefully you have another one for when it gets thrown out the window? :D
    i cant really help on cases though - sorry.
    oh and you'll need some "star" screw driver bits as it doesn't use normal screws.
    I'm on live tonight with a mate (a member here) i ask if he can help. :smashin:
    Gary
  7. Razor
    Razor
    Dec 15, 2004
    37,616
    2
    +12,442
  8. Pooon
    Pooon
    Dec 26, 2002
    7,367
    Canterbury, Kent
    +962
    Cheers razor, not really what i was looking for, but i think i could have another use for that paint thou
  9. Pooon
    Pooon
    Dec 26, 2002
    7,367
    Canterbury, Kent
    +962
    Seems that WhiteDog do coloured cases for £30 but it say the fron replacement panel only fits thomson drives, are they the ones with the holes in the tray?
  10. Razor
    Razor
    Dec 15, 2004
    37,616
    2
    +12,442
    LOL... :D
  11. John DB
    John DB
    Jul 29, 2002
    344
    +7
    Nah, Samsungs have the holes in the tray :)
  12. geewhizz
    geewhizz
    Jan 2, 2005
    2,458
    +89
  13. Pooon
    Pooon
    Dec 26, 2002
    7,367
    Canterbury, Kent
    +962
    thats a good site geewhizz. could come in handy for spares n such
