Colour uniformity with PT-AE100. Good reason for repair?
Discussion in 'Projectors, Screens & Video Processors' started by SanPedro, Aug 8, 2003.
  1. SanPedro
    SanPedro
    Jan 11, 2001
    4,497
    +503
    Hi all
    The image on my AE100 show definite colour uniformity problems, going from green on the right to red on the left. On a lot of brght colourful material you don't notice it but on very monochromatic stuff like the Matrix and the Intro to the last Harry potter film it's very noticeable.
    Is this uniformity a common fault? And is it a good enough reason to send it back for repair? Or is it a case of "they're all like that sir".
    Thing is... is it likely to get worse over the years?
    I wouldn't put up with it on a £300 TV from Comet, so why should I have to put up with it on a £1000 PJ?
    Chris
  2. stormywhether
    stormywhether
    Not got any of that going on with mine, Chris.
    I'd definitely be tempted to get em to take it back in for repair.
    Mind you, I'm a cretin when it comes to av stuff. I probably wouldn't notice for a couple of weeks if the bulb went pop!
  3. SanPedro
    SanPedro
    Jan 11, 2001
    4,497
    +503
    I only started noticing it on certain films. I saw a thread here a while back and they siggested going to the PJ menu, options, change background to grey and put an empty source through it (ie with no signal).
    Sure enough I sees the background isn't a uniform grey colour across the screen. Bummer. Question is whether this is normal.:(
    Chris
  4. cyberheater
    cyberheater
    Apr 3, 2003
    3,186
    Scotland
    +170
    No. This is not normal. Get it back for repair.
  5. SanPedro
    SanPedro
    Jan 11, 2001
    4,497
    +503
    Cheers cyber
    Will get it bagged up Monday (need weekend fix:D)
    Chris
  6. stormywhether
    stormywhether
    you don't need no weekend fix man - it's gonna be a right scorcher.
    Unless you have a cellar home cinema!!
    At least contact Panny right away so they can arrange stuff.
  7. SanPedro
    SanPedro
    Jan 11, 2001
    4,497
    +503
    Yeah I know. But I won't be seeing it for a few weeks will I?
    So I shall have to say my farewells at least.
    I've just sent panasonic tech support an email. be interesting to see what they say. Think i might just invest in an extended warranty. My local AV supplier will do 3 yrs for £106 (excluding bulb). Which I think is cheaper than Panny's own.
    Chris
  8. stormywhether
    stormywhether
    Here, I'd be interested in taking out that 3 year warranty Chris - you got details? Could I take it out with them?
  9. cyberheater
    cyberheater
    Apr 3, 2003
    3,186
    Scotland
    +170
    It shouldn't take that long for repair. My power supply went this week. I phoned Panasonic on Wed morning. The collected it in the afternoon and I got it back today. Awesome customer service!!!
  10. SanPedro
    SanPedro
    Jan 11, 2001
    4,497
    +503
    You got their number? Or is the website the place to look. I was figuring on taking it back to my dealer.
    Chris
  11. cyberheater
    cyberheater
    Apr 3, 2003
    3,186
    Scotland
    +170
    Try Panasonic on 08709 070909. The should fix you up no problem. Is yours still under warrenty
  12. SanPedro
    SanPedro
    Jan 11, 2001
    4,497
    +503
    Will get back to you on that. panny's warranty is for an additional 2 years. Not sure if this is the same or for an extra 3 years.
    Chris
  13. SanPedro
    SanPedro
    Jan 11, 2001
    4,497
    +503
    Cyber
    rang them Friday. They are supposed to be collecting today. damn right it's good service. And it's still under warranty. Phew!
    chris
  14. SanPedro
    SanPedro
    Jan 11, 2001
    4,497
    +503
    Stormy
    Warranty is with a company called Novasure. I can get mine through my local Dealer, Roy Jowett of Colne, Lancs. tel: 01282 863823
    2 yrs; £64 up to 5 yrs at £282. This seems bloody good value. doesn't include the lamp though.
    There are other links to them on the web I came across. look under novasure warranty.
    Chris
