SnakePlissken006
Even if Linux works then the problem is still on windows which I need so what difference would that make?If you are not interested in trying all possible solutions, why post?
Try a different software.
Try a different cable.
Try a different monitor/TV
Try Displayport
If after you have tried all of the above, and it still occurs, your GPU is probably faulty
I've actually tried a different hdmi cable.
I don't have another monitor to test it on. Even so why would that make a difference if I was to find a monitor that it worked on? The whole point is to Try and get my computer working with my tv which it should be able to. Plus I've already ruled out my tv being the problem as I've tested the same games on console which I posted above.
If you're not going to help then don't post.
