Colour Manipulation?
Discussion in 'Photography Forums' started by Garrett, Oct 9, 2004.
  1. Garrett
    Garrett
    Apr 21, 2001
    42,902
    2
    167
    The best thief you'll never see.
    +8,032
    I took two pictures yesterday of the same subject one it nearly filled 66% the screen and the other nearly 50% both time near enough centre of the picture.
    On looking at the pictures afterwards the second ones colour's were too strong, but the first the composition of the shot was not quite right can I alter the colours of the second to match exactly the colours of the second using Photoshop Elements?
    See attachments of a small part of the pictures below the first is too strong in colour.
  2. Northerner
    Northerner
    Aug 12, 2003
    112
    19
    The land where The Macallan is distilled
    Is this what you want to achieve? Just fiddled about with the lightness (not brightness) and saturation controls. You can acess them from the "Enhance" menu on Photoshop
  3. Garrett
    Garrett
    Apr 21, 2001
    42,902
    2
    167
    +8,032
    Cheers :smashin: .
    I have just tried it and can get it very near the only thing it seems to lighten the blacks down a bit.
    Is there anyway to bring them back up without altering the rest of the picture?
  4. Northerner
    Northerner
    Aug 12, 2003
    112
    19
    OK - now you need the Brightness/Contrast from the "Enhance" menu.
    this time I've raised the CONTRAST every so slightly but try it yourself to see if you can get the desired effect
  5. sorbiegunner
    sorbiegunner
    Jan 16, 2004
    184
    Try leaving the brightness, contrast, hue.... etc. settings alone and tweak the levels or curves.
  6. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +226
    Would recommend Curvemeister (at www.curvemeister.com) as a nice, to must have, plug in for Elements, it's available as a "try out".
