Rokko ru7400
Corret signal, I'm take auto or wide on the hdr? TV lg nanocell sm8200 65
Wide is always wrong. It should never be used.Corret signal, I'm take auto or wide on the hdr? TV lg nanocell sm8200 65
It should always be on Auto in both HDR and non-HDR mode. In RGB mode you may want to set Black Level to High for full-range RGB sources like a PC.Thanks for the answers you are very experienced, I would like a correct setting in hdr, (car/wide/extended color space) game even with xbox one x same problem do not know which is correct, thanks for the answers
SDR is BT.709 or sRGB, and HDR is BT.2020. Wide is incorrect for both. Auto is the correct option for both modes.Ok thanks for the answer, so I select auto in both sdr and hdr situations? The TV automatically shows the colors as it receives them from the signal in auto mode
