Color temperature for PLUS Piano Avanti HE-3200
Discussion in 'Projectors, Screens & Video Processors' started by VABA, Mar 18, 2006.
  1. VABA
    VABA
    Does anyone knows how can I adjust the 3 basic colors from the 'custom' menu of my PLUS Piano Avanti HE-3200 in order to get the much desired 6.500 K white temperature? :thumbsup:
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,236
    +3,101
    You need to use a device that can actually measure the white to black greylevels. This could be a spectroradiometer or a tri-stimuls device. You are NOT aiming for 6500K. You are aiming for a thing called D65 which has specific co-ordinates on the CIE chart.
    Gordon
  3. VABA
    VABA
    Thank you for the replay and I really Knew all that....the thing is that I was wondering if anyone have done all that to his Piano Avanti HE - 3200 so I can spare all the truble (and cost :clap: ) just by adjusting the three basic colors as he have....
    But anyway thank you for telling me all that.
  4. Gordon @ Convergent AV
    Jul 13, 2000
    14,236
    +3,101
    Each system is iindivdual. You cannot use someone elses settings and expect them to be correct. It may be closer to correct or indeed it might be further away.
    Gordon
  5. VABA
    VABA
    You are 100% right! The adjusting has to be for my projector, the lamp of which has a sertain intensity.....how naive of mine :rolleyes:
    Thank you for the guidance :lesson: .....I know have to search for a specialist to calibrate my projector.
    Take care!
