Cokin P seires
Discussion in 'Photography Forums' started by vulkan75, May 7, 2007.
  1. vulkan75
    vulkan75
    I bought a cokin circular polarizer(p164) for my cokin filter system and I cant for the life of me work out how it fits.Ive been on the website and checked the manual and it should just slot in but it dont:confused: Its too big.
    anyone had issues with this.
  2. tryingtimes
    tryingtimes
    Feb 15, 2001
    4,094
    +531
    The grooves nearest the lens take it - flange at the lens-side.
    Unless I've got it completely wrong!
    If you're still struggling I'll take a photo in a bit.
  3. h4rri
    h4rri
    Mar 22, 2006
    1,988
    +159
    Make sure the grooves on the filter are closest to the camera end of the filter and slide it into the wider grooves on the filter holder
  4. Tobers
    Tobers
    Nov 4, 2005
    4,089
    Guildford
    +893
    Yep - quite right. I had the same problem. It's easiest to fit it with the holder off the camera.
  5. vulkan75
    vulkan75
    Great..thanks chaps sorted.:thumbsup:
