Cokin and Hitech filters - help
Discussion in 'Photography Forums' started by jools230575, May 11, 2005.
  1. jools230575
    jools230575
    Hi people
    Looking in to buying a combination of a Cokin filter holder and using filters by Hitech
    Has anyone else on the list done this?
    Was reading that you could use Hitech filters with the Cokin holder.
    The lens I am putting it on is the standard kit lens with the Canon EOS 350D. The diameter is 58mm.
    Anyone out there able to help? And also, can anyone provide me with a retailer that is reliable for ordering Hitech filters?
    Thanks :D
    Jools
  2. mattym
    mattym
    Jul 31, 2003
    2,116
    maidstone
    +101
    the filter from cokin will either be an A or P series, i believe the only difference is the material of the filter, my cokin holder has a 58mm ring to fit to the front of the my 300d, then the filter holder fits that...if the hitech filters are the same size as ckin ones it should all fit.
    no idea where to get them
