Cokin 77mm Adapter?
Discussion in 'Photography Forums' started by rizingstar, Sep 8, 2007.
  1. rizingstar
    rizingstar
    Aug 28, 2007
    1,015
    Newcastle Upon Tyne
    +187
    I'm after a 77mm adapter ring to fit my cokin 'p' filter holder onto the sigma 10-20mm lens,obviously being wide angle I'm not sure if the cokin 'p' is best for this?
    Anyone know the cheapest and best way to go around this?
    tia :thumbsup:
  2. stevegreen
    stevegreen
    May 14, 2001
    8,746
    in my Hymer
    +921
    The Cokin P series is fine for a Sigma 10-20mm however, you will need to get the wide angle holder to avoid severe vignetting. You will still get some at 10-12mm but it's liveable with. You will need the 77mm adaptor ring and the wide angle holder. here
  3. rizingstar
    rizingstar
    Aug 28, 2007
    1,015
    Newcastle Upon Tyne
    +187
    Would a Kood P series 77mm adapter work with the cokin holder?
    7dayshop sell them for a few quid
    edit: don't think they are wide angle tho?
  4. stevegreen
    stevegreen
    May 14, 2001
    8,746
    in my Hymer
    +921
    I think the Kood adaptor will work with the Cokin holder, but it would be worth checking further. The Cokin adaptor rings aren't that expensive anyway, maybe £9?
    Remember, you need an adaptor ring that screws to your lens and then the holder slots onto that, the filters then slide into the holder. I use the WA holder all the time and have never had the normal holder. It does limit somewhat with the ability to stack filters but I have never found it a major problem.
