Does anyone know if it's possible via a Pronto CCF to open the disk tray on a Yamaha S540 DVD Player - the remote for the player doesn't have a button for it so I dont know if it can be done.
OK, so pressing stop for a couple of seconds will open the tray - does anyone know if this can be replicated using TV Remote on a PDA - I've got a button set to mimic the Stop button but it doesn't seem possible to duplicate the stop button being pressed down for a few seconds.
Hi John,
I think only the hard keys can emit long enough signals, I have this problem with a Panasonic TV's power button.
Try and do repeated, fast pressing of the button.
Ged
Did you know the left and right menu arrows give fast forward and rewind, I think in the manual it says to use the chapter buttons, doing the latter sometimes causes chapter skipping by accident.
