Code for Sony RM-932
Discussion in 'Blu-ray & DVD Players & Recorders' started by Dumble452, Jul 29, 2004.
  1. Dumble452
    Dumble452
    I have recently purchased a budget DVD player Yakumo XL2 http://www.amazon.co.uk/exec/obidos/ASIN/B0000UIXTU/ref=br_ce_ts_1//026-0958342-6838807 with which I am very pleased, other than the remote control is very bulky and retro. My Sony TY has a universal remote commander, but unfortunately Sony do not appear to list a code anywhere for this to perform basic functions for the Yakumo DVD player. If anyone knows what this code is or how to obtain it I would be very grateful.
  2. sapper44
    sapper44
    Feb 12, 2004
    551
    uk
    +64
    Try having a look in the manual for the remote.There may be a way of training the remote so it will opp the dvd player.I think what happens is you press some keys while pointing at the dvd until the unit switches off using the remote or something like that.
  3. Dumble452
    Dumble452
    All the codes for DVD players listed in the hand book are between 001 and 030, I've tried all of them with no luck.
