Code For Pan 32-PF10?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Gadjet, Mar 23, 2002.
  1. Gadjet
    Gadjet
    Aug 14, 2001
    411
    Wrexham
    +7
    I have found out to get remote control working again-if the codes worked have any one out there got the correct code for the PF10-32 please?
    Your help would be appreciated,
    Phill:confused:
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    If you are referring to the code used to enable the SKY D remote to control a Pana TV then it's 0051, any trouble ring SKY and they will talk you thorugh the procedure and I believe have more codes than are printed in the manual.
